Comparata all'attualità della git2 come la vedete?
Inviato dal mio SM-G920F utilizzando Tapatalk
General Complete name : 20150820_105408.MOV Format : MPEG-4 Format profile : QuickTime Codec ID : qt File size : 41.1 MiB Duration : 15s 500ms Overall bit rate : 22.3 Mbps Encoded date : UTC 2015-08-20 10:54:08 Tagged date : UTC 2015-08-20 10:54:08 Writing library : icat Video ID : 1 Format : AVC Format/Info : Advanced Video Codec Format profile : High@L4.0 Format settings, CABAC : No Format settings, ReFrames : 2 frames Codec ID : avc1 Codec ID/Info : Advanced Video Coding Duration : 15s 500ms Bit rate : 20.9 Mbps Width : 1 920 pixels Height : 1 080 pixels Display aspect ratio : 16:9 Frame rate mode : Constant Frame rate : 30.000 fps Color space : YUV Chroma subsampling : 4:2:0 Bit depth : 8 bits Scan type : Progressive Bits/(Pixel*Frame) : 0.335 Stream size : 38.5 MiB (94%) Language : English Encoded date : UTC 2015-08-20 10:54:08 Tagged date : UTC 2015-08-20 10:54:08 Audio ID : 2 Format : PCM Format settings, Endianness : Little Format settings, Sign : Signed Codec ID : sowt Duration : 15s 400ms Bit rate mode : Constant Bit rate : 1 411.2 Kbps Channel(s) : 2 channels Channel positions : Front: L R Sampling rate : 44.1 KHz Bit depth : 16 bits Stream size : 2.59 MiB (6%) Language : English Encoded date : UTC 2015-08-20 10:54:08 Tagged date : UTC 2015-08-20 10:54:08
