Nuova gimbal Tarot 3 assi per GoPro 3 3+ 4
appena ordinata, spedizione DHL, appena mi arriva posto qualche foto e una recensione
Tradotto con Google dal cinese...
Tarot T4-3D three-axis-stabilized head designed for GOPRO HERO3 / HERO4 the same size and weight of the camera customization, integrated TAROT series PTZ all high-end technology. Using a combination of aluminum and plastic structure, bringing light weight and stability of the strongest, even in extreme harsh environments, also accurate to lock the camera to maintain a high degree of stability, output ultimate experience of fine industrial grade screen, is the best choice for professional video and aerial photography enthusiasts.
Tarot T4-3D triaxial auto-PTZ PTZ advanced control algorithms, built-in independent IMU precise attitude control PTZ, PTZ integrated servo drive module. Support point to follow (PF) and the first person (FPV) modes. All the power and signal lines subtly embedded in the head structure. Speed controllable pitch axis, the rod corresponds to the amount of rocker shaft rotational speed of the pitch, the greater the amount of rotation of the lever faster.
Product Features:
Support computer interface set point follow mode (PF)
First-person mode (FPV)
Built-in independent IMU modules
TAROT PTZ dedicated servo drive module
AV output interface supports a wide range of input voltage support conventional receiver / S-Bus receiver / DSM receiver peripherals:
Support Camera Type: GOPRO HERO3 / HERO4 the same size and weight of the camera input power: 2S ~ 6S LiPo Battery mechanical / electrical characteristics:
Angle control accuracy: ± 0.02 °
Maximum controllable speed:
Pitch direction (TILT): ± 200 ° / s
Controllable pitch direction of rotation range (TILT): -120 ° to + 15 °
Working Current: 30mA (@ 25V) 50mA (@ 12V)
Stall Current: 350mA (@ 25V) 700mA (@ 12V)
Working temperature: -20 ° C ~ 50 ° C
Weight: 178g
Size: 99mm × 88.5mm × 105.6mm
Scheduling software installation requirements:
Windows XP; Windows VISTA; Windows 7; Windows 8 (32 or 64 bit)
Product Specifications:
Triaxial brush head × 1
PTZ control module × 1
PTZ and PTZ main body cable × 1
5V output, the receiver and video cable × 1
USB Module × 1
Flight control cable × 1
Box × 1
Product Features:
Weight: 178g
USB Module × 1
Box × 1
