Originariamente inviato da Joe08
Nuovo Hubsan X4 H501S fpv
ATTENZIONE
è stato individuato un nuovo bug sull'ultima versione del firmware FC del quadricottero 1.1.21.
In pratica appena il drone, in volo, si trova inclinato di almeno 82°, si disarmano automaticamente i motori, sia che stiate volando in GPS HOLD che ALT HOLD.
In ogni caso, pare che a giorni ci sarà una grossa novità da parte di HUBSAN, circa il rilascio di un firmware
questa è la comunicazione riporta sul noto forum
"Attention: Your prayers have been answered
To all free flyers in the forum here, I have a momentous announcement.
We have heard thy cries of frustration, observed thy tears of despair. Our good engineer amidst cases of repair bade me bring thee these words heralding great cheer:
We now have an official firmware configuration, or firmware "package" and two new releases of firmware in this particular package that will allow you to fly at a maximum height of 250 meters- and up to 800 meters with decent video feed (800 meters tested at a height of 150 meters).
I dub it the Super Flyer package. If you wanted the ultimate configuration for maxed out video and flight range, this is it. I will be releasing it when I get back from lunch, along with a new firmware upgrade instructional video starring none other than yours truly. It will be as detailed as possible, to help with the confusion. It really is not a very complicated process- just finicky. However once learned it really is quite easy. I'm a beginner and I learned it pretty much right away!
Paradox_Pete, Chris48, The_Kurd, and everyone else in here. I know you guys were asking about the differences between the firmwares, to try and get max range on video and flight. This is the all in one answer. This is even a version that you guys can DIY, for you coders out there.
No more needing to search for best possible configurations of firmware for range! Stay tuned. We will be mass messaging our customer support team in China to make sure they know about this as well, because we know you guys have been dying for some consistency"
Originariamente inviato da lukappaseidue Visualizza il messaggioATTENZIONE
se ho capito bene dovrebbe quasi essere perpendicolare al regolare assetto di volo.....e in gps hold rimane sempre stabilizzato.......
......forse se urta un ostacolo .....non riuscirebbe mai a "riprendersi" ???...è questo il problema ?...HUBSAN H501S FPV - BLADE INDUCTRIX - CHEERSON CX1
Originariamente inviato da paolomasse Visualizza il messaggio...forse sbaglio.... ma come si può in GPS HOLD far inclinare il drone più di 82 gradi ?....
Nell'attesa mi sa che torno alla versione 1.2.x mi sono stancato di questa calibrazione bussola ogni due secondi che non serve a niente a meno che non si decisa di fare zone che non si conosce dove per precauzione uno la può fare manualmente.
Inoltre voglio provare il famoso abbinamento radio TX 4.2.8 RX 1.2.3 che a detta di Luka dovrebbe avere piu potenza segnale. Leggendo la fonte del forum straniero piano piano mi sto convincendo.
Capita molto spesso che per rientrare in normative CE i droni vengono depotenziati appositamente. Potrebbe essere questo il caso.
Originariamente inviato da Farrr Visualizza il messaggioVi faccio queste domande perchè mi sono perso.
Quali versioni di firmware consigliate di installare ad oggi?
Io ho la radio FPV1.
Dove trovo le varie versioni? Sul sito HUBSAN ne trovo solo una.
Grazie!RallyLegend,Losi22,DurangoDex210,Traxxas-Slash2wd, XK X251,JJRC X1,Hubsan x4,
XK DETECT 380,Hubsan H501S,ARX 540
qui il video :
https://www.youtube.com/watch?v=v3-R8d60WZY
Originariamente inviato da x5494 Visualizza il messaggioIl drone non è infallibile, proprio per nulla, basta una discesa un po' repentina e un colpetto di vento ed è facilissimo che si inclini così. Se invece di riprendere quota si spegne i motori non sarebbe il massimo.
Grazie!
Per il momento puoi installare solo il firmware FC 1.1.21 che ha questo bug dello spegnimento motori, durante il volo, se il drone assume una inclinazione di circa 82°.
Tieni conto che la versione 1.1.17 ne ha ben 8 (non documentate) di possibilità di spegnere in volo i motori, accidentalmente.
Comunque a breve dovrebbe essere rilasciato un pack software da HUBSAN.
ho fatto già due prove con la radio TX 4.2.8
e il segnale 2.4 è davvero piu stabile. Con l'altra versione a 200m già si iniziava ad avere piccoli problemi di comandi al drone. Ora invece no. Probabilmente è davvero più potente il segnale così.
Tuttavia non sono riuscito a far funzionare la combinata TX 4.2.8 RX 1.2.3 perché non mi si calibrava la bussola.
Ho dovuto usare TX 4.2.8 RX 1.2.9 e la bussola funziona bene. Il motivo è un mistero, ho visto è successo anche a uno di quel forum russo che ha linkato Luka in qualche pagina indietro di questa discussione.
Nessun'altro ha fatto questa prova? sempre su quel forum ho scaricato le varie versioni.
Originariamente inviato da x5494 Visualizza il messaggioho fatto già due prove con la radio TX 4.2.8
Originariamente inviato da giusepperossetto80 Visualizza il messaggioMa la mia che ho trovato cioè la 1.1.9 è male?
Anche lui può avere qualche bug. Se ovviamente il drone va bene, non è necessario fare l'aggiornamento, anche se, solitamente, gli aggiornamenti portano migliorie e correzione di bug (e introduzione di nuovi bug )
Per quanto riguarda il firmware FC 1.1.21, io sono per l'aggiornamento.
Peraltro, se è vero che è stato scoperto che con questa versione il drone, se raggiunge la inclinazione di 82°, spegne i motori, è anche vero che con la 1.1.17 sono ben 8 le possibilità non documentate di spegnere i motori in volo; quindi, a conti fatti, il rischio maggiore si corre proprio con la versione 1.1.17 (per chi lo ha, provi a mettere le levette del controller tutte in basso convergenti, in basso divergenti, in alto convergenti, in alto divergenti... insomma guardatevi il video
https://www.youtube.com/watch?v=wHr5Y9ihj04
Peraltro, se è vero che è stato scoperto che con questa versione il drone, se raggiunge la inclinazione di 82°, spegne i motori, è anche vero che con la 1.1.17 sono ben 8 le possibilità non documentate di spegnere i motori in volo; quindi, a conti fatti, il rischio maggiore si corre proprio con la versione 1.1.17HUBSAN H501S FPV - BLADE INDUCTRIX - CHEERSON CX1
