E' ora di cominciare a testare i nuovi FW
// uncomment the lines below to save on flash space if compiling for the APM using Arduino IDE. Top items save the most flash space #define LOGGING_ENABLED ENABLED // disable dataflash logging to save 11K of flash space #define MOUNT DISABLED // disable the camera gimbal to save 8K of flash space #define AUTOTUNE_ENABLED ENABLED // disable the auto tune functionality to save 7k of flash #define AC_FENCE ENABLED // disable fence to save 2k of flash #define CAMERA DISABLED // disable camera trigger to save 1k of flash #define CONFIG_SONAR DISABLED // disable sonar to save 1k of flash #define POSHOLD_ENABLED ENABLED // disable PosHold flight mode to save 4.5k of flash #define AC_RALLY DISABLED // disable rally points to save 2k of flash, and also frees rally point EEPROM for more mission commands #define PARACHUTE DISABLED // enable parachute release at a cost of 1k of flash #define CLI_ENABLED DISABLED // enable the CLI (command-line-interface) at a cost of 21K of flash space #define OPTFLOW DISABLED // enable optical flow sensor and OF_LOITER flight mode at a cost of 5K of flash space #define SPRAYER DISABLED // enable the crop sprayer feature (two ESC controlled pumps the speed of which depends upon the vehicle's horizonta$ #define EPM_ENABLED DISABLED // enable epm cargo gripper costs 500bytes of flash #define NAV_GUIDED DISABLED // enable external navigation computer to control vehicle through MAV_CMD_NAV_GUIDED mission commands
