Rivolto ai Guru: (Drone) faccio bene o sbaglio tutto?
Ciao a tutti, dopo circa tre mesi di ricerche a documentarmi sui vari forum nonche' guardare centinaia di video fino alla noia, avrei stilato una lista di componenti per costruirmi un esa-rotore di fascia bassa (almeno credo).
A causa di un infortunio sul lavoro che mi ha costretto a svendere i miei vecchi amati velivoli a scoppio con annessi accessori, ora che per fortuna va un po meglio ho il desiderio sfrenato di fare dei filmati decenti con un drone, esa-rotore, o come dirsi voglia.
Di seguito la lista, spero completa, fatta eccezione di gimbal e action cam, presa dal non poco blasonato sito Hobby king.
https://www.hobbyking.com/hobbyking/...mm_Black_.html
https://www.hobbyking.com/hobbyking/...Lipo_Pack.html
https://www.hobbyking.com/hobbyking/...GPS_Combo.html
https://www.hobbyking.com/hobbyking/..._CCW_2pc_.html
https://www.hobbyking.com/hobbyking/...on_Green_.html
https://www.hobbyking.com/hobbyking/...bag_8x3_8.html
https://www.hobbyking.com/hobbyking/...ess_Motor.html
https://www.hobbyking.com/hobbyking/...ontroller.html
https://www.hobbyking.com/hobbyking/...out_Cable.html
https://www.hobbyking.com/hobbyking/...airs_bag_.html
https://www.hobbyking.com/hobbyking/...s_GENUINE.html
https://www.hobbyking.com/hobbyking/...rap_330mm.html
https://www.hobbyking.com/hobbyking/...X_LCD5802.html
https://www.hobbyking.com/hobbyking/...et_RP_SMA.html
https://www.hobbyking.com/hobbyking/...and_RC832.html
https://www.hobbyking.com/hobbyking/...t_Mode_2_.html
https://www.hobbyking.com/hobbyking/...er_S_Spec.html
https://www.hobbyking.com/hobbyking/...apter_Set.html
https://www.hobbyking.com/hobbyking/...6S_XT_90_.html
https://www.hobbyking.com/hobbyking/...e_Charger.html
https://www.hobbyking.com/hobbyking/...dview_888.html
https://www.hobbyking.com/hobbyking/...nt_System.html
https://www.hobbyking.com/hobbyking/...ansmitter.html
https://www.hobbyking.com/hobbyking/...0pcs_set_.html
https://www.hobbyking.com/hobbyking/...uard_1pc_.html
https://www.hobbyking.com/hobbyking/...7x10_5pc_.html
So che ci sono accessori doppi per l'FPV, batterie e qualche elica di troppo ma visto i costi di spedizione nonche' doganali, ho preferito avere diverse scelte.
Scusandomi fin da ora per l'ennesima lista dei "consigli per gli acquisti", sperando di aver postato nell'area giusta, vi sarei davvero grato nel darmi qualche feedback sia negativo che positivo in merito.
Ho cercato anche di entrare in un range accettabile di efficienza grazie all'applicazione in parte gratuita eCalc.
Grazie a tutti.
Tony.
Grazie a tutti.
Tony.
