Spetta la 4000+ arriva a 1440....
General Complete name : 2015_0709_082020_003.MP4 Format : MPEG-4 Format profile : Base Media / Version 2 Codec ID : mp42 File size : 276 MiB Duration : 1mn 54s Overall bit rate mode : Variable Overall bit rate : 20.2 Mbps Movie name/More : DEMO1 Encoded date : UTC 2015-07-09 08:22:14 Tagged date : UTC 2015-07-09 08:22:14 Origin : NVT-IM Video ID : 1 Format : AVC Format/Info : Advanced Video Codec Format profile : High@L5.1 Format settings, CABAC : Yes Format settings, ReFrames : 1 frame Format settings, GOP : M=1, N=15 Codec ID : avc1 Codec ID/Info : Advanced Video Coding Duration : 1mn 54s Bit rate : 20.1 Mbps Width : 2 560 pixels Height : 1 440 pixels Display aspect ratio : 16:9 Frame rate mode : Constant Frame rate : 30.000 fps Color space : YUV Chroma subsampling : 4:2:0 Bit depth : 8 bits Scan type : Progressive Bits/(Pixel*Frame) : 0.181 Stream size : 273 MiB (99%) Language : English Encoded date : UTC 2015-07-09 08:22:14 Tagged date : UTC 2015-07-09 08:22:14 Audio ID : 2 Format : AAC Format/Info : Advanced Audio Codec Format profile : LC Codec ID : 40 Duration : 1mn 54s Source duration : 1mn 54s Bit rate mode : Variable Channel count : 1 channel Channel positions : Front: C Sampling rate : 32.0 KHz Compression mode : Lossy Source stream size : 1.31 MiB (0%) Language : English Encoded date : UTC 2015-07-09 08:22:14 Tagged date : UTC 2015-07-09 08:22:14 mdhd_Duration : 114400
