La tarot
ha messo in vendita un esa copter Frame che vuole essere l'alternativa all's800
questa volta (rispetto la F680 esa ) i tubi sono diametro 25 in carbone.
Ha ancora la possibilità di essere ripiegato , con un sistema leggermente diverso dal F680 con boccole che lasciano a desiderare se usate parecchio tanto da costringere i clienti a praticamente non ripiegarlo.
Vedremo se sara un buon prodotto.
Product Features:
The overall use of imported pure carbon cover Toray carbon fiber 3K woven of pure, high temperature and pressure prefabricated full CNC precision machining.
Pure carbon matte twill carbon fiber quality beyond conventional commercially available products, integrated performance beyond national standards for carbon fiber strip
Plate of high strength level performance requirements.
Quick folding system can be directly mounted safe and reliable line, avoid the use of plug circuits.
Cover all with self-locking nut M3 PTZ panel in carbon fiber, the thread has a unique design structure using self-locking screw technology,
Has excellent resistance to lateral vibration.
Rapid innovation adoption folded portion ¢ 40 Falcon riveting metal dovetail design, with a strong clamping force.
Full carbon nanotubes have excellent damping when folded slip handle.
Lightweight two-color multi-axis CNC machining using motor unit, the overall design has a strong perspective effect, as the body of the air
Provide striking visual orientation. Multi-standard high-current slip gilded interior locking hubs.
Flight load 3 kg, design compressive load 15 kg.
Product parameters:
Weight: 1020G
Tube diameter: 25MM
Wheelbase: 810MM
Rack Diameter: 850MM
Center Cover Size: 210 × 210 × 2.0MM
Motor mounting pitch: 16MM/19MM/25MM/27MM equilateral triangle shaped mounting
Recommended configuration:
4114/320KV multi-axis brushless motor TL100B08
1555 high carbon fiber multiaxial pros paddle TL2812
30-35 multiaxial ESC
6S battery 10000-15000MAH
Specifications:
T810 folding six-axis rack × 1
Coated diamond rasp × 1
Decal set × 1
Colored sticker set × 1 point
Velcro × 1
Manual × 1
Spare screw pack × 1
Accessories:
T810 full carbon tube rack (349MM) TL96011
T810 folding frame full carbon tubes TL9609
T810/T960 six-axis rack battery holder TL9608
M4 alloy butterfly screws TL9606
Multiaxis metal locking clamp TL9605
T810/T960 folding six-axis body cover TL9604
Six groups TL9607 Tarot Hub
New Φ25MM Motor Mount / Black TL9603
New Φ25MM Motor Mount / Orange TL9602
T810, T960 metal reinforcing plate TL9601
Φ25MM head tube clamp / Black TL100A01-1
Eight axes Φ25MM pure carbon fiber tripod TL100B05
4114/320KV multi-axis brushless motor / Orange TL100B08-02
4114/320KV multi-axis brushless motor / Black TL100B08-01
1555 (wing tip) efficient multiaxial carbon fiber paddle TL2813 pros
T810/T960 folding tripod TL96013
T810/T960 head mount kit TL96014
T810/T960 under mount battery holder group TL96015
Side panels, hood edge protector TL2768
Product parameters:
Weight: 1020G
Tube diameter: 25MM
Wheelbase: 810MM
Specifications:
Decal set × 1
Velcro × 1
Manual × 1
Accessories:
