Non riesco a impostare la modalità tuttala nel mio rvosd, ho provato a cercare ma ho trovato poco niente... Nel menù autopilot ho impostato il parametro.. però mi si muove solamente l'elevone di destra. Nei collegamenti ho in un servo aileron e nell'altro elevator... ho sbagliato a fare i collegamenti?? Come posso collegare correttamente e impostare tutto?
RVOSD impostare tuttala.
Hi,
Vova here )
RVOSD will handle elevon mixing.
Main menu, page 4/4
Autopilot output:
Select the output mode of the autopilot.
*Airplane: All outputs will match the board labels.
-Elevator output --> Elevator
-Aileron output --> Aileron
-Throttle output --> Throttle
-Rudder output --> Rudder
*Flying wing:
-Elevator output --> Elevon 1
-Aileron output --> Elevon 2
And then
-For flying wing the OSD will make the elevon mixing, disable elevon mixing on your transmitter if you had it set to do so, and connect RVOSD like this:
· Rx auxiliary output ----> OSD auxiliary input
· Rx Elevator output ----> OSD elevator input/output ----> Elevon1
· Rx Aileron output ----> OSD aileron input/output ----> Elevon2
· Rx Throttle output ----> OSD throttle input/output ----> ESC
Make sure the Elevons move to the appropriate directions when you move the elevator and aileron sticks, else reverse the directions on the transmitter. If after this you still cant set directions to work you could try to reverse the setting of the OSD menu item Elevon-aileron CH1(Main menu page 4/4) and try again.
direi che siamo apposto
