Ciao ragazzi,
cercavo l'occasione di un bel ed economico esacottero, e non ho resistito al nuovo Esacopter MJX. C'è anche il fratello minore identico, ma con 4 motori.
Gia il precedente modello 600 andava bene, ma questo ha delle caratteristiche che mi hanno molto incuriosito
L'ho preso da Gearbest che ha ora il pezzo piu basso. Per 65 euro spedito hai un Esacottero che è un ugrading del famoso X600
MJX X601H Air Pressure Altitude Hold WiFi FPV 720P CAM 2.4GHz / 4CH 6 Axis Gyro Hexacopter Headless Mode-71.67 and Free Shipping| GearBest.com
Le caratteristiche che sono curioso di provare sono
1) Mantenimento quota tramite sensore di pressione atmosferica
2) 6 Motori potenti che mi permettono anche di tirare su una mobius o una Yi
3) FPV in 3D: Supporto per i Vr Glass anche in 3D
4) Flight Plan
Main Features:
Air pressure altitude hold /atmospheric pressure sensitive height hold function improves aerial photography and video recording performance. Push up the throttle control stick to take off the drone. When the drone is flying more than 1 meter height, release the throttle stick, the drone will keep hovering at the current height.
The "MJX H" APP with 2 modes: Real-time images transmission mode and mobile phone app control mode ( for controlling movements ).
WiFi FPV function can be achieved through the connection of the model and the smart phone if download and install the FPV software to your smart phone.
headless mode, completely solving pilot "loss of orientation" problems.
360 degree rollover / 3D flip function makes your aircraft turning around and around likes a excited bird, let's enjoy more fun of rolling.
one key automatic return function, you can call back your copter quickly and safety.
135mm diameter coreless motors, the hexacopter shows a strong power.
You can also enjoy some basic functions like forward / backward / up / down / turn left / turn right / sideward flight.
USB cable length is about 63cm.
Supports VR glasses to improve your first person view experience but not included.
Battery
Battery: 7.4V 700mAh
Flying Time: 8~9mins
Charging Time (h): About 2
Battery Size: 3 x 1.2 x 5.5cm
Battery Weight: About 37g
Camera
Video Resolution: 720P
Dimension and Weight
Product weight: 0.205 kg
Flight Plan e Vr 3D
App
Radio
Fpv
Spero mi arrivi presto
