SHENGKAY D97, recensione
  • SHENGKAY D97, recensione
    A giorni avrò sotto mano questo modello,il D97 gentilmente inviato da Gearbest.
    Queste le caratteristiche tecniche per il momento. Poi seguirà una bella recensione con test di volo.
    Nel frattempo per chi vuole lo può trovare qui:
    SHENGKAI D97 Quadcopter-54.82 and Free Shipping| GearBest.com
    con questo codice di sconto SKD97C valido fino al 31 ottobre. Stay tuned!!
    Main Features:
    WIFI FPV system allows real time image transmission with WIFI connection between the quadcopter and your phone. From now on, your smartphone will be the most easy-taking and removable FPV monitor.
    HD camera with high 2-mega-pixel, give you a clear view as you were just there.
    With phone holder, you can hold your phone on the transmitter conveniently.
    Throwing flight function and 360 degree rollover makes you more enjoy the fun of rolling.
    Overcharging protection and memory function keeps the quadcopter safe and easier to play.
    2.4GHz transmitter power ensures the strong anti-jamming capability.
    About 100 meters control distance improve the flight performance.
    6 axis gyro fly system with the more sensitive of gyro’s regulating, more stable and flexible flight.
    With attractive headless mode, completely solving pilot “loss of orientation” problems.
    With controllable light, give you more chance for playing all those functions.
    Specification:
    Copter Size: 32 x 32 x 9cm
    Charging Time: About 40min
    Flying Time: About 7min
    Frequency: 2.4GHz
    Gyro: Build-in 6 Axis Gyro
    Camera Pixel: 2-mega-pixel
    Control Distance: About 100m
    Copter Battery: 3.7V 600mA Li-po Build-in Battery
    Control Battery: 4 x 1.5V AA Battery (Not Included)
    Function: WIFI FPV, Up / Down, Left / Right Sideway Fly, Forward / Backward, Headless Mode, 360 Degree Rollover, Turn Left / Right, One Key Automatic Return, Throwing Flight, Film and Shoot, Overcharging Protection, Memory Function
    tutti i miei video
    tutte le mie recensioni
    D97 arrivato. Sto iniziando la recensione, appena la termino posto tutto. Nel frattempo a prima vista molto simile esteticamente al syma x5.
    tutti i miei video
      Facci sapere!!! :-)
      Inviato dal mio GT-I9505 utilizzando Tapatalk
      Punix
      Member of www.orangeteam.it
        mancano i test di volo, spero di trovare un po di tempo nei prossimi giorni.
        Metto intanto un link della recensione che aggiornerò mano a mano e poi riporto qui tutto.
        https://recensionigearbest.wordpress...97-quadcopter/
        tutti i miei video
          riporto tutto qui:
          Il D97 della casa Shengkay è un quadricottero che dall'aspetto vuole richiamare alla memoria il famoso syma x5. Esso però si differenzia per alcune caratteristiche tecniche e di volo che andremo poi ad analizzare.
          Confezione e contenuto:
          Come di consueto alcune caratteristiche dell'imballo, una classica confezione in cartone con maniglia superiore per il trasporto.
          Rispetto alle altre confezioni noto un tipo di cartone forse un po troppo poco rigido che con il trasporto ne risente. Nessun problema comunque all'interno dove trova posto ciò che è più importante.
          Il contenuto della confezione è il seguente: il D97 con la sua radio in 2.4 Ghz, tracolla, supporto per cellulare, un set di due eliche, il caricabatterie USB, paraeliche, carrellini di atterraggio, cacciavite e i manuali d'uso per il controllo del mezzo e per la gestione della cam da remoto.
          D97 nel dettaglio:
          Il D97 con il paraeliche montato ha un ingombro di 32x32 cm, questo scende a 29.5 cm senza paraeliche. Interasse motore in diagonale di 22.5 cm. Monta eliche da 13.5 cm bloccate al centro con una vite a stella.
          Il carrello, una volta montato sotto al D97, porta la sua altezza a 10 cm lasciando spazio sufficiente alla camera per la trasmissione fpv. Il peso in ODV è di 114 grammi.
          Scende a 108 grammi senza i 4 paraeliche che posso essere montati facilmente senza dover smontare nulla grazie ai due fori laterali dove si inseriscono due perni presenti ai lati del paraeliche e al foro centrale dove una vite tiene ben saldo il tutto.
          Il sistema di trasmissione è il classico a ingranaggi. Questi sono a vista nella parte inferiore, personalmente avrei preferito una copertura in plastica per evitare che sporco e quant'altro possa entrare e rovinare gli ingranaggi in plastica. Fino ad ora non ho comunque riscontrato problemi di questo genere.
          per ogni braccio sono installati 4 led di colore rosso frontalmente e di colore verde al posteriore. Anche qui avrei optato per il contrario, verde davanti e rosso dietro. Rimangono sempre accesi e sono ben visibili anche di giorno.
          Sul lato posteriore è presente il tasto on off che permette di spegnere il quadricottero senza dover staccare ogni volta la batteria.
          tutti i miei video
            Come dicevo sotto il D97 trova posto il gruppo cam-tx wifi per la trasmissione del video visibile direttamente sul cellulare tramite app che poi andremo a vedere. La cam viene dichiarata da 2 mega pixel, vedremo dopo la qualità delle immagini.
            La cam è collegata alla scheda di controllo tramite micro connettore che porta direttamente e sempre tensione al sistema fpv. E' installata sotto il vano batteria e non serve smontarla per accedere alla batteria stessa.
            Il gruppo ottico può essere inclinato a piacimento per ottenere l'angolo di inquadratura più desiderato. Il peso della cam è molto contenuto, 10 grammi. Visto che lo smontaggio è molto semplice ho avuto modo di guardare la scheda interna. Purtroppo il processore è stato raschiato per non permettere l'identificazione. qui sotto le due facce della scheda.
            Come dicevo il vano batteria e subito sopra la cam e all'interno troviamo una lipo da 3.7 v 600 mAh. che permette un tempo di volo di circa 6/7 minuti. La batteria ha il suo connettore "losi" e le dimensioni sono 24 mm di base, 41mm di altezza e 8.2 mm di spessore. Il peso è di 14 grammi.
            In generale la costruzione e la qualità delle plastiche è ben curata, le finiture buone e anche la resistenza agli urti per il momento è in linea con tutte le alltre marche fino ad ora provate. Esteticamente come detto all'inizio assomiglia molto al syma x5, si differenzia per qualche accorgimento tipo i piedini sotto ai motori, che qui sono più corti. Nel complesso quindi un buon mezzo per imparare senza ansie di rompere qualcosa dal costo elevato.
            Il radiocomando:
            Il radiocomando ricorda la classica forma "professionale", anche se più piccolo e plasticoso. Non è presente nessun dispaly se non una etichetta finta. E' presente il tasto di accensione, con un led rosso. Sulla parte superiore ci sono due tasti frontali. Quello di sinistra permette di scegliere tre modalità di volo con risposte più o meno veloci ai comandi. Il tasto di destra permette di fare evoluzioni 3d. Quando premuto il quadricottero effettua la rotazione su se stesso in base al comando dato. Il tasto di trim presente sottoal gas in realtà attiva la funzione headless o il return to home, (vedi foto in basso). Per quanto riguarda la calibrazione dell'accelerometro da radio è valida la solita procedura, stick del gas a destra e stick pitch in basso a destra per tre secondi. Il quad lampeggerà e verrà effettuata la calibrazione (da fare ovviamente su superficie piana).
            In dotazione c'è il supporto per collegare lo smartphone direttamente sulla radio per poter vedere direttamente sul display il video ripreso dalla camera installata a bordo e poter scattare foto e registrare il video stesso.
            tutti i miei video
              L'alimentazione della radio viene data da 4 batterie stilo tipo AA. I prossimi giorni inizierò il cambio di mode della radio dissaldando i relativi potenziometri e creando i ponti necessari sulla scheda. Aggionerò la recensione appena possibile.
              All'interno della radio troviamo questa componentistica:
              Applicazione su smartphone:
              Come indicato sul foglio illustrativo in dotazione è possibile scaricare un'app per sistema iOS e android che permette di gestire il sistema fpv wifi. una volta scaricata l'app e installata l'app permette alcune funzioni qui descritte:
              Non è operativo il controllo del D97 direttamente da smartphone ma tutte le altre funzioni relative alla camera sono operative.
              In volo:
              Il D97 non delude le aspettative di questo genere di quadricottero. Il decollo è subito stabile e non necessità di interventi ai trim. Le tre modalità di volo, impostabili con il tasto superiore sinistro della radio, permettono di aumentare la risposta ai comandi. In modalità slow il principiante ha modo di imparare il controllo del mezzo mentre in medium e high la risposta del quadricottero è sempre più reattiva e si riesce a manovrare anche in presenza di brezza senza nessun problema e inoltre il comando yaw nell'ultima modalità ha una buona risposta, non velocissimo ma sufficiente per manovre veloci. I flip vengono compiuti con velocità discreta, non è un asso nella velocità ma vengono completati in modo preciso e il D97 non perde troppa quota.
              Per quanto riguarda l'headless mode è stato sempre preciso e funzionale; Non altrettanto preciso l'automatic return, diciamo che tenta di tornare verso di voi ma non ha nulla a che fare con i veri return to home gestiti da gps. Stiamo parlando di un quadricottero dal costo decisamente contenuto e privo di elettronica ad Hoc per la gestione perfetta di questa funzione.
              Buono invece la funzione FPV, tenendo in considerazione che si tratta comunque di una trasmissione wifi con i suoi limiti di campo e un leggero ritardo delle immagini (frazioni di secondo). Per l'uso che però deve essere fatto va più che bene e anche la qualità video non è malaccio in condizioni di luce diurna. Diciamo che per un primo approccio a questo sistema di pilotaggio, per poi passare eventualmente a cose più professionali, il sistema fpv in dotazione garantisce un minimo di esperienza in questo mondo.
              Conclusioni:
              In conclusione il D97 permette con un prezzo contenuto, sia di imparare a pilotare un quadricottero sia di provare una prima esperienza di volo fpv senza tante pretese. Nei pochi test di volo che ho potuto effettuare in questi giorni non ho avuto problemi ne di portata radio ne di trasmissione fpv. La casa dichiara 100 metri di range, possibili magari con la radio ma difficilmente con il sistema wifi. Ad ogni modo tutto l'insieme permette di divertirsi senza spendere un capitale e farsi le ossa per futuri sistemi più costosi.
              Dove acquistare il D97:
              Lo shengkay D97 è acquistabile in offerta speciale con questo codice di sconto: SKD97C valido fino al 31 di ottobre.
              Questo il link diretto per l'acquisto: shengkay D97
              tutti i miei video
                Grazie!
                Ottima recensione,
                appena ordinato, credo che per 42 euro non si possa ottenere di meglio
                  Originariamente inviato da maxidvd Visualizza il messaggio
                  Ottima recensione,
                  ti ringrazio, spero ti sia stata utile.
                  Nel frattempo ho voluto invertire il mode passando da mode 2 a mode 1:
                  Aggiornamento 2/10/2015:
                  Dopo alcuni tentativi sono riuscito a modificare la radio e portarla da mode 2 a mode 1, portando cosi il controllo del gas a destra. Per effettuare questa operazione bisogna dissaldare tutto il gruppo potenziometri per invertire la posizione e poi ponticellare gas e pitch/roll con le rispettive vecchie piazzole di collegamento interrompendo le piste dove necessario. Oltre a questo però ho dovuto creare uno scanso sulla scheda radio per mantenere il gas nella giusta posizione. Deve quindi essere ripristinata la pista interrotta per far posto al potenziometro gas (cavo rosso lungo). Altra cosa da ricordare è che girando in questo modo il gruppo potenziometro gas i 4 piedini esterni non hanno più corrispondenza con i fori sulla scheda madre (non sono a quadrato ma disposti su forma rettangolare), quindi bisogna poi ripristinare i ponti di massa che si creavano con le saldature di fabbrica (cavetto blu e rosso corto). La modifica con un minimo di manualità con il saldatore tutto sommato non è difficile, questo quello che ho ottenuto:
                  Ho fatto diversi tentativi prima di arrivare a questa soluzione, le saldature che si vedono sul comando sinistra/destra e yaw in realtà non servono in questi due potenziometri. Massa, segnale e positivo devono rimanere come da fabbrica.
                  tutti i miei video
                    Direi che è il miglior cloneclone x5c attualmente disponibile. Complimenti per la recensione!
                      aggiungo un video test di volo...
                      tutti i miei video
                        Salve ma i ricambi si trovano? Sono gli stessi del Syma x5c o x5sc? In particolare mi interessa sapere se sono uguali i ricambi dei motori, eliche, paraeliche, ingranaggi e piedini di atterraggio. Chiedo questo perché di tale modello non ho trovato parti sostitutive.
                          Originariamente inviato da andrealopresti6 Visualizza il messaggio
                          Salve,
                          Sono questi ricambi di Shengkai D97 che sta cercando?
                          Buon Compleanno Gearbest
                          Tanti sconti su https://goo.gl/1qdPio
