Chiedo scusa
  • Chiedo scusa
    Scusandomi per le innumerevoli domande a volte fuoriluogo, ho raccolto un po' le idee sottoponendole prima di procedere all' acquisto su Hobbyking
    Camera spec.
    CCD sensor type:1/3 color SONY CCD
    Pixel;
    NTSC: 510(H)*492(V)
    PAL: 500(H)*582(V) (Included)
    Scanning system: Interlaced scanning
    Synchronization: System:Inter
    Horizontal resolution: 420TV line
    Minimum Illumination 0.01LUX/F1.2
    DSP+CCD: CXD3142R+405AK
    S/N Ratio: 48dB
    Gamma Modification: 0.45
    White balance: Auto
    Auto backlight compensation: Auto
    Lens: 3.6MM
    Audio: No
    Input voltage: 9~12.6V
    Electric current 80MA
    Electronic Shutter: 1/50 (60) ~ 1/100,000s
    Video output: 1.0VP-P composite video
    Operation Temp.: -20~50
    Flight time: Approx 60min/100mah 3S
    5.8Ghz Receiver only
    The RC805 5.8Ghz AV Receiver features a digital channel display and jumperless, one press channel selection. This receiver also includes an additional AV output for video recording while using FPV goggles.
    Specs.
    Receiving sensitivity: < -90dBm
    Receiving frequency: ISM 5.8GHz 8CH
    Antenna port: 50ohm SMA
    Antenna: Gain: 2dBi
    Power supply: DC12V 220mA
    Video output level: 1Vp-p @ 75ohm
    Audio output level: 1Vp-p @ 10Kohm
    Dimensions: 72.5x54.2x15.5mm
    Weight: 52g (w/antenna)
    Channels.
    CH1:5705 - CH2:5685 - CH3:5665 - CH4:5645
    CH5:5885 - CH6:5905 - CH7:5925 - CH8:5945
    5.8Ghz 200mW transmitter. This system is Good for up to 500m flying with the supplied antenna. An optional directional antenna can extend range to 1km+. This unit a Includes built-in microphone. The receiver unit has additional AV outputs for video recording while using FPV goggles.
    Specifications:
    Output impedance: 50Ohm
    Output power: 21~23dBm
    Channel frequency 1~8: 5705/5685/5665/5645/5885/5905/5925/5945mhz.
    Transmitter operating voltage: 7~15VDC / 150mA
    Receiver operating voltage: 5VDC
    Operating temp: -10~85C
    Video bandwidth: 0~8.0MHz
    Audio frequency: 6.5MHz
    Video input level: 0.8~1.2Vp-p
    Video input impedance: 75Ohm
    Audio input level: 0.5~2.0Vp-p
    Audio input impedance: 10K/Ohm
    Weight: 25g
    Antenna connector: SMA
    Dimensions: 55x26x17mm
    Extend the range of your FPV system with this Omnidirectional high-gain 2.4ghz antenna.
    Spec.
    Plug: SMA (male)
    Height: 380mm
    Sensitivity/Gain: 9dBi
    Turnigy FPV Goggles offer exceptional value for money. Featuring a 320 x 240 4:3 Display with AV in, 50in virtual image and a 900mah lithium battery.
    A great entry-level goggle which can be modified for a ski-mask or used as is for casual not-so-serious FPV fun.
    Specifications:
    Resolution: 320 x 240
    Ratio: 4:3
    Battery: 900mah lithium
    Virtual Image size: 50in
    Format: PAL/NTSC
    Includes:
    AV Cable
    Head phones
    External 900mah battery
    AC Charger
    Manca qualcosa ?
    Il primo volo e' come " la prima volta”………. non sai mai come "viene"
    no, per partire va bene. valuterei l'acquisto degli occhiali da farsi in un secondo tempo e partire con un monitor. se poi t'acchiappa invece dei turnigy potrai prendere direttamente i fat shark che costano di più. lo suggerisco perchè se hai un monitor a portata di mano risparmi per ora sugli occhiali e li prenderai solo se e quando sarai sicuro che l'FPV ti piace, spendendo un po' di più ma avendo un prodotto di ottima qualità. parere personale.
      Originariamente inviato da luca1970 Visualizza il messaggio
      CUT
      Manca qualcosa ?
      La camera fa schifo, la lente non è ottimale, gli occhiali fanno schifo e sono quasi inutilizzabili (specie per iniziare), l'antenna ricevente è sbagliata e il sistema di trasmissione a 5.8 ha diverse controindicazioni ed è adatto solo in alcune condizioni...
      Insomma...
      Vai da qualcuno che voli in fpv, guarda cosa usa e fatti consigliare su quello che vuoi fare te...
      Johnny
      (GTE - Torino)
        Grazie mille della gentilezza, vorrei ancora sapere se necessito ancora magari di una batteria per alimentare la trasmittente a bordo e poi se non risultano piu' comodi gli occhiali, esenti da riflessi, piuttosto che un monitor ?
        Se hai consigli sei il benvenuto, non vorrei fare compere che poi non so cone assemblare, grazie
        Altro ?
          Per gli occhiali prendi i fat shark, li vende HK per il kit wireless ti consiglio quello di sunsky 1.2 ghz da 800 mw
          Per le batterie dipende, se hai spazio sul modello è meglio tenere le alimentazioni separate, Cam e tx video dal resto altrimenti potresti avere delle interferenze nel video.
            ops, non avevo notato che l'antenna non era per i 5.8
            come vedi l'FPV non è una scienza esatta, ognuno ha le sue preferenze. come già ti abbiamo accennato faresti meglio a darci più dettagli su ciò che vuoi fare: ad esempio i 5.8 vanno bene per alcune cose ma non per altre etc etc
            per la domanda sulla batteria credo che se ancora non hai bene capito come la cosa funzioni ti conviene passare un po' più di tempo sul forum e sui vari siti dedicati per avere le idee più chiare.
