Naza V2 + GPS
  • #46
    DJI ha fatto comunicato ufficiale x la Naza V2:
    Ci sara anche sul sito ufficiale della DJI
    DJI adheres to continuous innovating and improving, with the new firmware, new attitude stabilization algorithm and optimized hardware structure, the Naza-M V2 provides better flight performance. The innovative All-in-one design simplifies installation and saves space and weight. It contains inner damping, controllers, 3-axis gyroscope, 3-axis accelerometer and barometer in its light and small Main Controller. It can measure flying altitude, attitude and therefore can be used for autopilot/automatic controlling.
    The latest fourth generation attitude stabilization algorithm not only inherits the outstanding flight stability of DJI products, but also provides excellent maneuverability. It is more flexible and stable, and gives the hobbyists a wonderful flight experience. New features have been included such GPS course automatic compensation, GPS & Compass sensor calibration, new take-off mode and so on.
    FUNCTIONS
    • Manual Mode( user select Manual, Atti and Failsafe);
    • Atti. Mode;
    • GPS Atti.Mode;
    • Intelligent Orientation Control(CF):Course lock/Home lock
    • Enhanced Fail-Safe:Landing / go home & landing;
    • Quad-rotor I, X; Hex-rotor I, V; Y, IY; Octo-rotor X, I, V;
    • Combination Stick Command to start; Immediately Mode and Intelligent Mode to stop;
    • Remote gain tuning;
    • Two-axis gimbal supported, Multi Gimbal Servo Output Frequency Supported;
    • Support Normal receiver, D-Bus Port support S-bus and PPM receiver;
    • Voltage Monitor and Low Voltage Protection;
    • 4 channels transmitter support;
    • Five-level Motor Idle Speed adjustable in Motor Mixer;
    • IMU Calibration function and Auto course error compensation;
    • Support PMU extend module, could connect with IOSD, H3-D2 gimbal and Bluetooth module;
    WHAT’S NEW?
    FIRMWARE
    • New attitude stabilize algorithm, provides better flight performance;
    • New flight control feeling(takeoff is more stable and easy;flight will be more smooth);
    • Auto course error compensation;
    • Support octo-rotor; Add protection for Hexa-copter, octo-copter when lost one motor power;
    • Add IMU advanced calibration, sensor error monitoring and protections function;
    • Support PMU module with CAN BUS port, could support iOSD, GoPro gimbal and Bluetooth LED module, and so on;
    • Increased demand for GPS signal strength, increased the compass interference monitoring and warning, maximumly reduced the effects of magnetic disturbance;
    • Add new LED information;
    SOFTWARE
    • New UI design, simple and easy to use.
    MANUAL
    • New Quick Start Guide, matched with the new assistant software;
    NOTICES
    • For safety reason, do not use power battery during firmware upgrade.
    • Make sure reconfigure all parameters after upgrading firmware.
    • #47
      DJI Innovations | Naza-M V2
      avevo scordato il link
      • #48
        Bello ... Certo è che se mettevano anche funzionalità di Waypoint, magari a numero ridotto, era perfetto.
        • #49
          il prezzo di questa nuova v2 completa di gps? e la sola PMU V2 per upgrage della naza v1?
          il gps della v1 è uguale a quello della v2 o bisognero prenderlo nuovo?
          • #50
            Originariamente inviato da budfox77 Visualizza il messaggio
            .. a qul prezzo ? e chi compra poi il wkm?
            puoi chiedergli se ti aggiungono qualche etto di culatello
            • #51
              Originariamente inviato da fulvico Visualizza il messaggio
              Si, chiedo troppo per quel prezzo ... Magari con upgrade a pagamento ...
              Tanto il NAZA rimarrà sempre una "versione demo" del WKM...
              E poi c'è la concorrenza che ti apre i waypoint ...
              • #52
                ma dei prezzi e della disponibilità non si sa ancora niente?
                • #53
                  Naza V2 si potranno fare anche gli optocopter
                  Ultima modifica di Blade-slap; 04 ottobre 13, 05:38.
                  • #54
                    Qualcuno sta provando la v3 beta?
                    Il mio canale youtube
                    • #55
                      Credi che anche il V1 possa essere upgradato per config octa?
                      • #56
                        io vorrei provare la beta 3 ma non si capisce bene dove si possa scaricare...
                        • #57
                          La beta version 3 non la poi provare e dato solo ai betatester.
                          Ma aspetta e questione di poco e potrai provarla direttamente sulla tua V1 scaricando dal sito DJI.
                          • #58
                            Buongiorno a tutti, sono nuovo, ma da tempo seguo l'evoluzione dei multirotori.
                            Da quello che ho letto in queta discussione... a prescindere di un probabile aggiornamento software / firmware per NAZA V1, possibile che la NAZA, come ha scritto qualcuno di Voi faccia fare un upgrade hardware o riprenda addirittura indietro dell'hardware già venduto??
                            Come dicevo seguo la scena da tempo, ma forse il campo modellistico ha subito delle variazione nell'ultimo decennio dall' ultima volta che ho praticato.
                            La NAZA V2 a mio avviso è una linea completamente nuova, gia dal differente colore che ha dato a questo ultimo nato.
                            • #59
                              Che la DJI riprenda indietro il sistema completo Naza V1 + GPS , e pagando un delta si possa avere la Naza V2 + GPS....questo non e stato confermato e solo per ora un desiderio di molti.
                              mentre come ho gia scritto è sicuro che si potra comprare la PMU V2 ed il nuovo led , per poter accedere alle nuove funzioni della V2 ( IOSd .....) ..non e ancora sicuro che con l'upgrade si possa accedere a tutte le nuove funzionalità.
                              • #60
                                Intanto se si vuol dare uno sguardo ai manuali
                                DJI Innovations | Naza-M V2 Downloads
